QuickCAD (Read Only)
Convert Drafix .cad file to Autocad 2010.. need help
5 REPLIES 5
JGutsch
7026 Views, 5 Replies
I have some old .cad files I would like to re-use. They were last saved in 1997/1998 with .cad file extension. I think I was using Drafix but not sure. Can anyone convert for me? (File attached)
Jack
5 REPLIES 5
s0ckm0nkey
in reply to: JGutsch
Hi don't have a solution to conversion yet, but can tell you that your file was created in Drafix:
February 15, 1996
Drafix Windows CAD
IBM PC
DOS 3.0
MS 2.1
1989 Foresight Resources Corp.
Best of luck.
johnsdtn40
I have an old copy of Drafix running I will try to download the file and convert it an Autocad file.  Where can I contact you off the borad?
John Davis
johnsdtn40
in reply to: johnsdtn40
I was able to convert it to a .DWG and a DXF file  I hope it helps.
John Davis
s0ckm0nkey
For information:
I think that AutoSketch 10 has included the facility for opening old Drafix files. Once open you can save as AutoCAD .dwg.
Glad you got it sorted.
Paddy-G
Hello John,
Was wondering if you could convert a few files for me.  I have run into these .cad files also and can't find anything to open them short of spending $150-200 and they just aren't worth that to do it.  If you could I would really appreciate it!
Patrick
P.S. I'll attach them later if are willing.
Thanks again!
