Normand Doiron wrote:
> If I want to change a dimension, how could I do??? If the real dimension
> is 4.986" and i need to put 5.000" on my plan, is it possible?
Select the dimension.
Right click
Select entities
In the Edit Entities, select dimension tab
In the label block replace <> with 5.000"
Alternative
If you have your edit toolbar on, once you select the dimension, the label
will appear in it. You can change it there.
Len Rafuse
Vision Engineering
