Does anybody know if it is possible to use a wildcard (*) in the value parameter of properties in the search take-off dialog box?
Here is my scenario, I have a building with concrete walls that are labeled "CON XX" where XX is the thickness of the wall. I need to take-off all of the concrete walls by floor level. There are about 6 thicknessess of concete walls on each floor (ex: CON 150, CON 238, etc.).
My approach thus far has been to do a search take-off and use the "base constraint" property (ex: floor 1) and "type name" property (ex: CON 150) to catalog items. However, this approach makes it time consuming because I have to repeat this process for each type of concrete wall on each floor.
What I would like to do is use the same method but for the "type name" property, use "CON*" so that it picks all of the type names with CON in them.
Is this possible? If not, is there any easier way?
thanks.
