Quantity Takeoff
Quantity Takeoff
Member
0 Kudos
Post 1 of 3
Accepted Solution
QTO will not open projects
1400 Views, 2 Replies
01-04-2012 11:29 AM
Two current (was working on them yesterday with no problems) QTO projects will not open on my computer.  The error message " There was a problem displaying the page" appears.  Both of these files will open on other computers in the office with the same (2012) version and hotfix level as my computer.
We have tried to reinstall QTO and it has not resolved the problem.
Anyone encountered this before?
The hotfix was allready installed.
Turns out the issue was associated with the windows user profile. When we logged on to the problem computer as a different user we were able to open the ato files.  Autodesk tech support confirmed this as the likely cause of the problem.  We deleted the user profile / recreated on the PC and were back in business.
*Expert Elite*
306 Kudos
Post 2 of 3
Re: QTO will not open projects
01-24-2012 06:19 PM in reply to: gdawson
Did you install the hotfix or are you just saying you have the same hotfix level as someone else for whom this works?
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Member
0 Kudos
Post 3 of 3
01-26-2012 02:55 PM in reply to: tcorey
Post to the Community
New Post
