Quantity Takeoff (Read Only)
qto crashes when printing with pdf
1 REPLY 1
p.dohmen
785 Views, 1 Reply
first qto (german version) had a problem with opening pdf.
after hotfis it crashes when printing with pdf behind.
anyone who has a solution?
cant even export as a new pdf...
thx
1 REPLY 1
dembkod
in reply to: p.dohmen
p.dohmen,
Hello. Thank you for the post. This is likely corrected in the QTO hotfix 2. Install Hotfix 1 and 2 and then try to open the file. The Hotfix 2 has corrected some PDF conflicts. Based on your submission, this could be your solution.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18403022&linkID=10381885
Thank you for participating in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
David Dembkoski
