Quantity Takeoff
Quantity Takeoff
Active Member
0 Kudos
Post 1 of 3
QTO and Revit
1143 Views, 2 Replies
02-24-2012 09:10 AM
Hi. I am new to QTO and still I am playing with it. Till now I do not see any need for this software if I am using Revit. I tried most of the features and I found that most of the functions of QTO are found inside schedules of revit including calculated values. On contrary, I found Revit is more powerful for:
1- Takeoff composite wall items like material takeoff.
2- Fast takeoff functions since no need to take off every item separately.
For AutoCAD users, I think QTO is somehow good and efficient
So, can anyone tell me if I am wrong and why I should use this software instead of Revit?
Mohamad Yamani
BIM Technical Manager
Kemet Corp.
Active Member
1 Kudo
Post 2 of 3
Re: QTO and Revit
05-17-2012 08:01 AM in reply to: Mohamed_Yamani
This could be a never ending discussion but the key differences are.
Integration with a 3rd party estimating system. Timberline or MC^2, or you can write some good VBA code that works wonders.
Visual Color Coded Takeoff confirmation - if its colored its counted. Possible with Revit just a bit clunky.
Qucikly arrange your takeoff items by dragging and dropping. You can do this with Revit schedules, but you need to "mark" your elements and then filter your schedule accordingly.  Not fast and not easy you always miss something and you never will be able to tell with a schedule.
2D integration and takeoff ability - you can combine model based estimating with on-screen takeoff.
Ease of use and less overwhelming.  Granted making a Revit schedule is easy, but to someone without any BIM experience will be confused.
New Member
0 Kudos
Post 3 of 3
Re: QTO and Revit
08-27-2012 03:38 AM in reply to: Mohamed_Yamani
We want to take report of structural steel from a revit model. Can you please help.
