hello,
After take MEP quantity off for plumbing, I got a result, but the result is a total amount such as the length of cold water pipe is 40.383 meter. I can't get classified result, like length of cold water which the diameter is 15mm are 13 meter. Does anyone know how get classified result sort by diameter for pipe? Thanks for replying!
have you figured this out yet? can you please post how you did that?
I am having the same issue, with Pipes and Fittings. All dimenssions are lumped together.
regards
