Quantity Takeoff
New Member
shawn.crowley
Message 1 of 2 (420 Views)
Documents Browser - Red 'X'
420 Views, 1 Replies
12-05-2011 05:55 AM
Sometimes when working in QTO 2012 my documents browser gets a red 'x' through the dialouge box.  I can still select views and see name previews when I hold my house over where the documents used to be, but am unable to seen anything.
All help is appreciated.
Shawn
Shawn Crowley
Technical Specialist
CADapult Ltd
http://www.cadapult.net
Empowering Design With Integrated Solutions
Product Support
dembkod
Message 2 of 2 (389 Views)
Re: Documents Browser - Red 'X'
02-14-2012 11:52 AM in reply to: shawn.crowley
Shawn,
Hello. Thank you for the post. The screenshot appears as though you are un able to render this particular pane. Do you have the updates installed? That would be the first step. Also, I would update your graphics card drives to see if this is a view issue.
Also, I would reset the window layout. Click Window > Reset Window Layout
If this does not help, you can try to reset your QTO user profile. Sometimes this helps. Simply rename the following folders:
C:\Users\**YOUR USED ID**\AppData\Roaming\Autodesk, Inc\Autodesk Quantity Takeoff 2012
C:\Users\**YOUR USERID**\AppData\Local\Autodesk, Inc\Autodesk Quantity Takeoff 2012
After they are removed, when you start QTO, it will rebuild these folders for you.
Thank you for participating in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
David Dembkoski
