Quantity Takeoff (Read Only)
categorising and separating similar items in QTO?
0 REPLIES 0
Message 1 of 1
942 Views, 0 Replies
Im using QTO with a model for automatic take off, and trying to find a way of differentiating between a flat plasterboard ceiling which should be meaured as an area, and a strip of plasterboard which should be measured as a liner measurement.
At the moment all i can seem to get is all platerboard ceiling as an area, so my question is can I get QTO to look at an item and if the width is less than a certain amount meaure it as a length, and if it is greater than this amount then measure it as an area? also is it possible to differentiate between vertical and horizontal items?
many thanks
0 REPLIES 0
