Recently i upgraded my pc from windows 7 to windows 8. After installing QTO 2013, when i tried to open an existing file made in QTO 2013 previously, it was not opening showing the message "this file is made in a newer version of QTO than installed version on this pc. so it can't be opened." Any solution. Experts plz.
Click right mouse button on Autodesk QTO icon and go to "check solution compatibilty" use" I ran this program on Win 7 correctly."
Icon should be on your desktop not on the ribbon!
Take care!!!!
To this day I believe that QTO2013 is one of the best quantity takeoff applications.
I also upgraded to Windows 8.1 lately, applied hotfix for QTO and use the compatibility mode.
I am able to use QTO partially. I can import pdf-s, but it fails to import some dwg-s (for example, if I create a new project and try to import a dwg it just says creating of project failed).
When I try to open my previously done projects (with Windows 7) that contain dwg-s it gives me the "Cannot open project. The project file you selected is from a version of the product that newer than the version you have installed" error.
Closing and reopening QTO helps for some projects, but for some it doesn't, thus making the application somewhat unreliable (didn't have those issues with Windows 7).
Has anyone encountered the same issues with Windows 8.1?
