MotionBuilder Forum
Welcome to Autodesk’s MotionBuilder Forums. Share your knowledge, ask questions, and explore popular MotionBuilder topics.
[Solved] KeyFrame UV
2 REPLIES 2
277 Views, 2 Replies
Hello everyone,
I am new to MOBU.. very new and have what I believe will be an easy question.
So I have a texture that I would like to animate base on U and V.
Things I don't know how to do are, set Keyframes, change the translation of U and V, and how to navigate to the translate node.
What I have so far
##Navigate to texture Files##
Texts = FBSystem().Scene.Textures
for Text in Texts:
if Text.Name == "AnimateTexture":
print Text.Name
Thats pretty simple.. I know. So where is this translate node located its not "Text.Translation" because that crashes MOBU.
Okay thats all for now.
****EDIT****
I have figured out how to move the UV coord and how to set a Key
for Text in Texts:
Text.Translation = FBVector2d(0,5) #set number for U and V
Text.Translation.Key()#then key
But how do I have the code move to a certain point in time(frame)? Lets say I need a key on frame 1 and 20.
2 REPLIES 2
joel.pennington
You can step the transport control forward in time and set a key
from pyfbsdk import *
player = FBPlayerControl()
for Text in Texts:
for frame in :
player.Goto( FBTime(0,0,0,frame) )
Text.Translation = FBVector3d(frame,5,0) #set number for U and V ## I had to use a 3D vector, not sure why
Or you can access the FBFCurve object of the texture and set keys at arbitrary time without
stepping the transport control forward. You can set keys on a specific curve, saving more space.
for Text in Texts:
Text.Translation.SetAnimated(True)#make translation animatable so it has an animation node
tAnimNode = Text.Translation.GetAnimationNode() # this is the translation animation node
tuAnimNode = # this is the U coord, which is called x...
tuAnimNode.FCurve.EditBegin() # the docs say to use this to allow key addition to a curve
for frame in :
tuAnimNode.KeyAdd(FBTime(0,0,0,frame),frame) # the time and the value
tuAnimNode.FCurve.EditEnd()
Product Designer for Virtual Production
Thanks! That worked like a charm. This mobu Python is slowly starting to make sense.
