Hi guys
I need help in Motion Builder 2014. This script "FBPlayerControl().SetTransportFps(FBTimeMode.kFBTimeMode120Frames)" won't work in this MB 2014 but I try in 2012 it work just fine. I need it to work in 2014 the error is "FBTimeMode object is not callable". Thanks in advance.
Gelo
Solved by cmot. Go to Solution.
Have you tried running just the line by itself? I'm on 2014 x64 and it works for me.
Strangely, the following line also works, which I tried in case the extra parens might give me the error you are receiving.
FBPlayerControl().SetTransportFps(FBTimeMode().kFBTimeMode120Frames)
Hi
It works now..that's wierd I know I tried that code just like you gave...but anyways thanks a lot 🙂
Gelo
