MotionBuilder Forum
Welcome to Autodesk’s MotionBuilder Forums. Share your knowledge, ask questions, and explore popular MotionBuilder topics.
Relation Constraint FCurve (%)
5 REPLIES 5
dnorthcutt
1004 Views, 5 Replies
Hey Guys,
I'm writing some tools right now to drive bone rotation via a Relation Constraint. I've got everything mostly worked out with creating and connecting nodes in the constraint - but I'm having a bit of trouble with the FCurve (%) node. Does anyone know how to add/modify keys on one of these via script? Any help or ideas would be appreciated. Thanks!
5 REPLIES 5
in reply to: dnorthcutt
As far as I know, the boxes in a Relation constraint are not animatable. This makes sense considering a Relation constraint is kind of like an expression you create through nodes instead of writing lines of code.
You can set the value of the input of the box if you want through something like this.
def FindAnimationNode( pParent, pName ):#standard find animation node def
lResult = None
for lNode in pParent.Nodes:
if lNode.Name == pName:
lResult = lNode
break
return lResult
constr = None
box = None
for thisConstr in FBSystem().Scene.Constraints:
if "Relation" == thisConstr.Name:
constr = thisConstr
if constr:
for thisBox in constr.Boxes:
if "FCurve Number (%)" == thisBox.Name:
box = thisBox
print box.Animatable #this shows up as False
if box:
nodeToSet = FindAnimationNode(box.AnimationNodeInGet(),"Position %")
nodeToSet.WriteData()
In scene with a relation constraint named "Relation" with a box in the relation constraint named "FCurve Number (%)"
I usually make a def like FindConstraint(constrName) and FindBox(constraint,boxName) when working with stuff like this.
dnorthcutt
Hey, thanks for the reply. I've got all the box building and connecting working -- I guess I was just hoping to automate the process of setting the keys within an FCurve box. Sounds like maybe it's not accessible via Python?
Do you mean this ?
Re-reading your post I think this is what you are looking for:
from pyfbsdk import *
lResult = None
lResult = lNode
break
return lResult
lRelation = FBConstraintRelation('TEST')
lFcurveBox = lRelation.CreateFunctionBox( 'Other', 'FCurve Number (%)' )
lValue = FindAnimationNode( lFcurveBox.AnimationNodeOutGet(), 'Value' )
lCurve = lValue.FCurve
lCurve.EditBegin()
lTime = FBTime( 0, 0, 0, 20 )
lKey = lCurve.KeyAdd( lTime, 20 )
lKeyFrame = lCurve.Keys
lKeyFrame.RightDerivtive = 7
lKeyFrame.LeftDerivative = 7
lCurve.EditEnd()
~Kristine
dnorthcutt
That's exactly what I was looking for - thanks a ton!
