I need to make a dialog box with lots of checkboxes and text fields, and collect their values upon hitting an apply button. I’m new to scripting in MotionBuilder, and am having trouble querying the value of checkboxes. Here is my sample code. I made this as small as possible. What supposed to happen is, if you hit the button, it will log the select state of the checkbox in the python editor. If you run this, you’ll notice that the select state always logs False regardless if the checkbox is selected or not. The 8th line is where it's not working.
Help VERY much appreciated.
from pyfbsdk import * from functools import partial def show_textbox_val(cb, control, event): cb.Refresh(True) print("cb.Caption = %s" % cb.Caption) print("cb.Selected = %s" % cb.Selected) print("cb.Enabled = %s" % cb.Selected) def PopulateLayout(mainLyt): VBox = FBVBoxLayout() #Region x = FBAddRegionParam(5, FBAttachType.kFBAttachLeft, "") y = FBAddRegionParam(5, FBAttachType.kFBAttachTop, "") w = FBAddRegionParam(5, FBAttachType.kFBAttachRight, "") h = FBAddRegionParam(5, FBAttachType.kFBAttachBottom, "") mainLyt.AddRegion("main", "main", x, y, w, h) mainLyt.SetControl("main", VBox) #Checkbox cb = FBButton() cb.Caption = "a caption" cb.Style = FBButtonStyle.kFBCheckbox #Button bt = FBButton() bt.Caption = "Apply" bt.OnClick.Add(partial(show_textbox_val, cb)) VBox.Add(cb, 20) VBox.Add(bt, 20) def CreateBoxShotTool(): global t t = FBCreateUniqueTool("Ugh") t.StartSizeX = 350 t.StartSizeY = 200 t.StartPosX = 500 PopulateLayout(t) ShowTool(t) CreateBoxShotTool()
Paul
Solved by robotProdigy. Go to Solution.
I’ll answer my own question. It’s the FBButton.state attribute.
So line 8 could have been replaced with
print("cb.State = %s" % cb.State)
