Public Test Forum
Code posting
4 REPLIES 4
Alexander.Rivilis
676 Views, 4 Replies
Code posting
' (C) Copyright 2011 by
Imports System
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
' This line is not mandatory, but improves loading performances
<Assembly: CommandClass(GetType(AutoCAD_VB_plug_in1.MyCommands))>
Namespace AutoCAD_VB_plug_in1
    ' This class is instantiated by AutoCAD for each document when
    ' a command is called by the user the first time in the context
    ' of a given document. In other words, non static data in this class
    ' is implicitly per-document!
    Public Class MyCommands
        ' The CommandMethod attribute can be applied to any public  member
        ' function of any public class.
        ' The function should take no arguments and return nothing.
        ' If the method is an instance member then the enclosing class is
        ' instantiated for each document. If the member is a static member then
        ' the enclosing class is NOT instantiated.
        ' NOTE: CommandMethod has overloads where you can provide helpid and
        ' context menu.
        ' Modal Command with localized name
        ' AutoCAD will search for a resource string with Id "MyCommandLocal" in the
        ' same namespace as this command class.
        ' If a resource string is not found, then the string "MyLocalCommand" is used
        ' as the localized command name.
        ' To view/edit the resx file defining the resource strings for this command,
        ' * click the 'Show All Files' button in the Solution Explorer;
        ' * expand the tree node for myCommands.vb;
        ' * and double click on myCommands.resx
        <CommandMethod("MyGroup", "MyCommand", "MyCommandLocal", CommandFlags.Modal)> _
        Public Sub MyCommand() ' This method can have any name
            ' Put your command code here
        End Sub
        ' Modal Command with pickfirst selection
        <CommandMethod("MyGroup", "MyPickFirst", "MyPickFirstLocal", CommandFlags.Modal + CommandFlags.UsePickSet)> _
        Public Sub MyPickFirst() ' This method can have any name
            Dim result As PromptSelectionResult = Application.DocumentManager.MdiActiveDocument.Editor.GetSelection()
            If (result.Status = PromptStatus.OK) Then
                ' There are selected entities
                ' Put your command using pickfirst set code here
            Else
                ' There are no selected entities
            End If
        End Sub
        ' Application Session Command with localized name
        <CommandMethod("MyGroup", "MySessionCmd", "MySessionCmdLocal", CommandFlags.Modal + CommandFlags.Session)> _
        Public Sub MySessionCmd() ' This method can have any name
        End Sub
        ' LispFunction is similar to CommandMethod but it creates a lisp
        ' callable function. Many return types are supported not just string
        ' or integer.
        <LispFunction("MyLispFunction", "MyLispFunctionLocal")> _
        Public Function MyLispFunction(ByVal args As ResultBuffer) ' This method can have any name
            ' Return a value to the AutoCAD Lisp Interpreter
            Return 1
        End Function
    End Class
End Namespace
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
4 REPLIES 4
  1. using System;
  2. using System.Reflection;
  3. using Autodesk.AutoCAD.Runtime;
  4. using Autodesk.AutoCAD.ApplicationServices;
  5. using Autodesk.AutoCAD.DatabaseServices;
  6. using Autodesk.AutoCAD.Geometry;
  7. using Autodesk.AutoCAD.EditorInput;
  8.
  9. [assembly: CommandClass(typeof(Rivilis.HatchUtils))]
  10.
  11. namespace Rivilis
  12. {
  13.   public class HatchUtils
  14.   {
  15.     [CommandMethod("RHB", CommandFlags.Modal)]
  16.     public void RHB()
  17.     {
  18.       Document doc = Application.DocumentManager.MdiActiveDocument;
  19.       Editor ed = doc.Editor;
  20.       PromptEntityOptions prOps = new PromptEntityOptions("\nSelect Hatch: ");
  21.       prOps.SetRejectMessage("\nNot a Hatch");
  22.       prOps.AddAllowedClass(typeof(Hatch), false);
  23.       PromptEntityResult prRes = ed.GetEntity(prOps);
  24.       if (prRes.Status != PromptStatus.OK) return;
  25.       using (Transaction tr = doc.TransactionManager.StartTransaction()) {
  26.         Hatch hatch = tr.GetObject(prRes.ObjectId, OpenMode.ForRead) as Hatch;
  27.         if (hatch != null) {
  28.           BlockTableRecord btr = tr.GetObject(hatch.OwnerId, OpenMode.ForWrite) as BlockTableRecord;
  29.           if (btr == null) return;
  30.           Plane plane = hatch.GetPlane();
  31.           int nLoops = hatch.NumberOfLoops;
  32.           for (int i = 0; i < nLoops; i++) {
  33.             HatchLoop loop = hatch.GetLoopAt(i);
  34.             if (loop.IsPolyline) {
  35.               using (Polyline poly = new Polyline()) {
  36.                 int iVertex = 0;
  37.                 foreach (BulgeVertex bv in loop.Polyline) {
  38.                   poly.AddVertexAt(iVertex++, bv.Vertex, bv.Bulge, 0.0, 0.0);
  39.                 }
  40.                 btr.AppendEntity(poly);
  41.                 tr.AddNewlyCreatedDBObject(poly, true);
  42.               }
  43.             } else {
  44.               foreach (Curve2d cv in loop.Curves) {
  45.                 LineSegment2d line2d = cv as LineSegment2d;
  46.                 CircularArc2d arc2d = cv as CircularArc2d;
  47.                 EllipticalArc2d ellipse2d = cv as EllipticalArc2d;
  48.                 NurbCurve2d spline2d = cv as NurbCurve2d;
  49.                 if (line2d != null) {
  50.                   using (Line ent = new Line()) {
  51.                     ent.StartPoint = new Point3d(plane, line2d.StartPoint);
  52.                     ent.EndPoint = new Point3d(plane, line2d.EndPoint);
  53.                     btr.AppendEntity(ent);
  54.                     tr.AddNewlyCreatedDBObject(ent, true);
  55.                   }
  56.                 } else if (arc2d != null) {
  57.                   if (Math.Abs(arc2d.StartAngle - arc2d.EndAngle) < 1e-5) {
  58.                     using (Circle ent = new Circle(new Point3d(plane, arc2d.Center), plane.Normal, arc2d.Radius)) {
  59.                       btr.AppendEntity(ent);
  60.                       tr.AddNewlyCreatedDBObject(ent, true);
  61.                     }
  62.                   } else {
  63.                     double angle = new Vector3d(plane, arc2d.ReferenceVector).AngleOnPlane(plane);
  64.                     using (Arc ent = new Arc(new Point3d(plane, arc2d.Center), arc2d.Radius, arc2d.StartAngle + angle, arc2d.EndAngle + angle)) {
  65.                       btr.AppendEntity(ent);
  66.                       tr.AddNewlyCreatedDBObject(ent, true);
  67.                     }
  68.                   }
  69.                 } else if (ellipse2d != null) {
  70.                   //-------------------------------------------------------------------------------------------
  71.                   // Bug: Can not assign StartParam and EndParam of Ellipse:
  72.                   // Ellipse ent = new Ellipse(new Point3d(plane, e2d.Center), plane.Normal,
  73.                   //      new Vector3d(plane,e2d.MajorAxis) * e2d.MajorRadius,
  74.                   //      e2d.MinorRadius / e2d.MajorRadius, e2d.StartAngle, e2d.EndAngle);
  75.                   // ent.StartParam = e2d.StartAngle;
  76.                   // ent.EndParam = e2d.EndAngle;
  77.                   // error CS0200: Property or indexer 'Autodesk.AutoCAD.DatabaseServices.Curve.StartParam' cannot be assigned to -- it is read only
  78.                   // error CS0200: Property or indexer 'Autodesk.AutoCAD.DatabaseServices.Curve.EndParam' cannot be assigned to -- it is read only
  79.                   //---------------------------------------------------------------------------------------------
  80.                   // Workaround is using Reflection
  81.                   //
  82.                   using (Ellipse ent = new Ellipse(new Point3d(plane, ellipse2d.Center), plane.Normal,
  83.                        new Vector3d(plane, ellipse2d.MajorAxis) * ellipse2d.MajorRadius,
  84.                        ellipse2d.MinorRadius / ellipse2d.MajorRadius, ellipse2d.StartAngle, ellipse2d.EndAngle)) {
  85.                     ent.GetType().InvokeMember("StartParam", BindingFlags.SetProperty, null,
  86.                       ent, new object[] { ellipse2d.StartAngle });
  87.                     ent.GetType().InvokeMember("EndParam", BindingFlags.SetProperty, null,
  88.                       ent, new object[] { ellipse2d.EndAngle });
  89.                     btr.AppendEntity(ent);
  90.                     tr.AddNewlyCreatedDBObject(ent, true);
  91.                   }
  92.
  93.                 } else if (spline2d != null) {
  94.                   if (spline2d.HasFitData) {
  95.                     NurbCurve2dFitData n2fd = spline2d.FitData;
  96.                     using (Point3dCollection p3ds = new Point3dCollection()) {
  97.                       foreach (Point2d p in n2fd.FitPoints) p3ds.Add(new Point3d(plane, p));
  98.                       using (Spline ent = new Spline(p3ds, new Vector3d(plane, n2fd.StartTangent), new Vector3d(plane, n2fd.EndTangent),
  99.                         /* n2fd.KnotParam, */  n2fd.Degree, n2fd.FitTolerance.EqualPoint)) {
  100.                         btr.AppendEntity(ent);
  101.                         tr.AddNewlyCreatedDBObject(ent, true);
  102.                       }
  103.                     }
  104.                   } else {
  105.                     NurbCurve2dData n2fd = spline2d.DefinitionData;
  106.                     using (Point3dCollection p3ds = new Point3dCollection()) {
  107.                       DoubleCollection knots = new DoubleCollection(n2fd.Knots.Count);
  108.                       foreach (Point2d p in n2fd.ControlPoints) p3ds.Add(new Point3d(plane, p));
  109.                       foreach (double k in n2fd.Knots) knots.Add(k);
  110.                       double period = 0;
  111.                       using (Spline ent = new Spline(n2fd.Degree, n2fd.Rational,
  112.                                spline2d.IsClosed(), spline2d.IsPeriodic(out period),
  113.                                p3ds, knots, n2fd.Weights, n2fd.Knots.Tolerance, n2fd.Knots.Tolerance)) {
  114.                         btr.AppendEntity(ent);
  115.                         tr.AddNewlyCreatedDBObject(ent, true);
  116.                       }
  117.                     }
  118.                   }
  119.                 }
  120.               }
  121.             }
  122.           }
  123.         }
  124.         tr.Commit();
  125.       }
  126.     }
  127.   }
  128. }
Expert Elite Member
  1. using System;
  8.
  9. [assembly: CommandClass(typeof(Rivilis.Purge))]
  10.
  12. {
  13.   public class Purge
  14.   {
  15.     [CommandMethod("MyPurgeAll")]
  16.     static public void MyPurgeAll()
  17.     {
  18.       // For AutoCAD 2013+
  19.       object adoc = Application.DocumentManager.MdiActiveDocument.GetAcadDocument();
  20.       // For AutoCAD 2012-
  21.       // object adoc = Application.DocumentManager.MdiActiveDocument.AcadDocument;
  22.       if (adoc != null) {
  23.         adoc.GetType().InvokeMember("PurgeAll", BindingFlags.InvokeMethod, null, adoc, null);
  24.       }
  25.     }
  26.   }
  27. }
Expert Elite Member
  1. using System;
  8.
  10.
  12. {
  14.   {
  17.     {
  39.                 }
  42.               }
  43.             } else {
  55.                   }
  61.                     }
  62.                   } else {
  67.                     }
  68.                   }
  81.                   //
  91.                   }
  92.
  102.                       }
  103.                     }
  104.                   } else {
  116.                       }
  117.                     }
  118.                   }
  119.                 }
  120.               }
  121.             }
  122.           }
  123.         }
  124.         tr.Commit();
  125.       }
  126.     }
  127.   }
  128. }
Expert Elite Member
using System;
namespace Rivilis
    public void RHB()
                int iVertex = 0;
            } else {
                  } else {
                  } else {
                      double period = 0;
        tr.Commit();
Expert Elite Member
