A SimpleMod plug-in is a deformation-type modifier that moves vertices around but does not change topology (adding or deleting vertices, faces, surfaces, lines, etc.)
There's always scripted Geometry plugins. There you have total freedom over mesh creation, and you could use the exiting mesh as a "compound" sort of like boolean. But it's obviously not a modifier but maybe an option.
-Johan
