hi there,
i'm trying to get a procedure call on particle collision, count 6 six frames, and stop the procedure.
for example, say: particle 1 collide with pCube1, dies and call the procedure (so far so good) then something happens for 6 frm (or whatever number of frames you like) and then it stops.
i've been stuck on this for a while... both with expressions or mel code.
thanks
f
for those who might be interested... i ended up with this:
int $crt = `currentTime -q`;
int $cnt = $crt + 5;
for($i = $crt; $i <= $cnt; $i++){
$tmr = `currentTime -edit $i`;
print ($tmr + "\n");
f
a different approach:
// procedure
global proc cnt(int $i) {
print ($i + ".\n");
// expression
int $i;
if ($i <6) {
cnt($i);
$i++;
} else {
print "hello\n";
$i =0;
thanks
f
