3ds Max Programming
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max SDK, Maxscript and Python topics.
Plugin on C#
1 REPLY 1
979 Views, 1 Reply
Plugin on C#
As i understand now possible to make plugin only on c#
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Autodesk.Max;
using Autodesk.Max.Plugins;
namespace Plane
public class PlaneDescriptor : ClassDesc2
IGlobal global;
internal static IClass_ID classID;
public PlaneDescriptor(IGlobal global_)
this.global = global_;
classID = global.Class_ID.Create(253674,23564);
public override string Category
get { return "Max .NET Tutorial"; }
public override IClass_ID ClassID
get { return classID; }
public override string ClassName
get { return "Plane"; }
public override object Create(bool loading)
return new Plane();
public override bool IsPublic
get { return true; }
public override SClass_ID SuperClassID
get { return SClass_ID.Geomobject; }
public class Plane : SimpleObject2
public override void BuildMesh(int t)
public override ICreateMouseCallBack CreateMouseCallBack
get { return null; }
public override RefResult NotifyRefChanged(IInterval changeInt, IReferenceTarget hTarget, ref UIntPtr partID, RefMessage message)
return RefResult.Succeed;
public static class AssemblyFunctions
public static void AssemblyMain()
var g = Autodesk.Max.GlobalInterface.Instance;
var i = g.COREInterface13;
i.AddClass(new PlaneDescriptor(g));
I am placing dll into bin/assemblies
This code dont works. Max crashes on start.What is wrong? May be problem with x64 platform? Please help who know how to make plugin on c#
1 REPLY 1
RaphaelSteves6487
yeah i'm currently trying to make the same thing work with no luck  and no i can't use CUIstuff since i need an actual object that "lives" in the scene and updates frame by frame, tick by tick; like the rest of the objects.
i am just looking to make a proper, nice integration; create from create panel, modify in.. well.. modify panel.. the works
any help on this would be greatly apprechiated
(i'm using max2013x64 and VS2010 in case one is interrested)
