.NET MDGMessage
.NET MDGMessage
KasumiL5x
.NET MDGMessage
KasumiL5x
Hey all.
I'm just wondering if anybody has a solution to, or has at least encountered the same issue I am having with the .NET api.
I'm writing a plugin that requires listening for nodes added and removed.  Previously, in both Python and C++, I've done this using MDGMessage's addNodeAdded/RemovedCallback.  In the .NET API, however, these seem to be essentially missing.  I had a browse of the DLL for the C# library, and the functionality appears to be there for the rest of the callbacks exposed, but the aforementioned callbacks are imlemented (?) in a mind-boggling way I can't seem to wrap my head around.
Can somebody please shed some light on this functionality in the .NET API?
Thanks.
KasumiL5x
Bumping this post due to months of inactivity. This is a pretty large oversight if it's not correctly implemented.
cheng_xi_li
Autodesk Support
Autodesk Support
Hi KasumiL5x,
I've logged this as defect in our system. It's going to be fixed in the future.
Yours,
Li
Any ETA for the fix?
