Is there a way to Assign Controller to multiple objects at once? It would seem i have to go through them one by one and assign them, problem with that is i have hundreds of objects to do this to - and this wont be the last time i will need to do this. I originally Googled for this answer but couldnt find any soloution.
Any help would be greatly appreciated.
Cheers.
Solved by Steve_Curley. Go to Solution.
( for o in selection do ( o.rotation.controller = TCB_Rotation() ) )
Hey mate, that worked great. I just need one for the position if you could help me out?
Position XYZ
Euler_XYZ Rotation XYZ
to TCB
Thanks mate i really appreciate it! 🙂
EDIT; I copied what you did and changed it to position and now it works fine.
Thanks very very much mate! 😄
( for o in selection do ( o.position.controller = TCB_Position() ) ) ( for o in selection do ( o.rotation.controller = TCB_Rotation() ) )
( for o in selection do ( o.position.controller = TCB_Position() o.rotation.controller = TCB_Rotation() ) )
