Hi, I want to select many edges with a fixed interval instead of 1, how do I do this? I certainly don't want type them all. Thank you so much!\
i.e.
$.EditablePoly.SetSelection #Edge #{1437, 1439, 1441, 1443}
But instead of typing them all, I want something like this:
$.EditablePoly.SetSelection #Edge #{1437..2..1443}
But I don't know how to write it in the right way.
Solved by Steve_Curley. Go to Solution.
( edgeSel = $.getSelection #Edge for i = 1437 to 1443 by 2 do edgeSel[i] = true $.setSelection #Edge edgeSel )Not necessarily the best way to do it, but probably the easiest to understand. If you need to do this a lot then turn it into a function which you can call with different parameters.
