3ds Max Programming
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max SDK, Maxscript and Python topics.
Multi Selection with interval
1 REPLY 1
389 Views, 1 Reply
Hi, I want to select many edges with a fixed interval instead of 1, how do I do this? I certainly don't want type them all. Thank you so much!\
i.e.
$.EditablePoly.SetSelection #Edge #{1437, 1439, 1441, 1443}
But instead of typing them all, I want something like this:
$.EditablePoly.SetSelection #Edge #{1437..2..1443}
But I don't know how to write it in the right way.
1 REPLY 1
Steve_Curley
I don't think the built in "ranges" can deal with that - you would probably have to deal with it manually. Assuming the object is an Editbale Poly then
edgeSel = $.getSelection #Edge
for i = 1437 to 1443 by 2 do edgeSel[i] = true
$.setSelection #Edge edgeSel
Not necessarily the best way to do it, but probably the easiest to understand. If you need to do this a lot then turn it into a function which you can call with different parameters.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
