3ds Max Programming
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max SDK, Maxscript and Python topics.
MaxScript: Controller value access
5 REPLIES 5
istan
612 Views, 5 Replies
Maybe I am missing something, but is it really not possible to access a certain key value without moving the timeslider to a certain time first?
There exists
node.controller.value
but without any time parameter..
I am looking for someting like this:
getvalue node.controller time
5 REPLIES 5
Steve_Curley
in reply to: istan
The value of a key at a specific time or the value of a controller at a specific time whether there's a key at that time or not?
For the former you'd have deal with the Keys arrays and determine if there's one at the specificed time.
For the latter "at time" appears to work.
For example, a simple box moving from a -X postion to a +X position over the default 100 frames (keys at frame 0 and 100 only):-
at time 50F $Box001.position.controller.x_position.controller.value
will return the X position of the Box at frame 50, regardless of the position of the time slider. Note - only tested in the Maxscript Listener, not in an actual script.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
istan
in reply to: Steve_Curley
Hi Steve,
thanks. Should be part of the mxs doc..
Istan
Steve_Curley
in reply to: istan
It sort of is, albeit implied rather than stated explicitly. Actually it was an inspired guess (or a wild stab in the dark) 😉
Max 2016 (SP1/EXT1)
istan
works - thanks!
Steve_Curley
in reply to: istan
You're welcome 🙂
Max 2016 (SP1/EXT1)
