Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
Keyboard shortcut for cycling through toolkit?
6 REPLIES 6
reid.j.w
969 Views, 6 Replies
 I am looking for a keyboard shortcut that will cycle between tools in the toolkit.
i.e. Each press of the "`" key would cycle through the tools: Select, Move, Rotate, Scale, Select, Move, Rotate, Scale etc.
Suggestions welcomed!
*Reason Being; I would like to assign the Touch Ring of my Wacom Cintiq 24HD to cycle through these tools.
Thank You in advance. Cheers!
6 REPLIES 6
reid.j.w
in reply to: reid.j.w
I have ventured into MEL scripting for a solution.
My approach is to assign the currently selected tool to a variable then utilize a switch statement.
...to be continued...
tony.su
You can try this - add this mel in Hotkey Editor.
int $Toolkit_Cycling;
$Toolkit_Cycling++;
if ($Toolkit_Cycling == 5) {$Toolkit_Cycling =1;}
switch ($Toolkit_Cycling) {
case 1:
SelectToolOptionsMarkingMenu;
break;
case 2:
TranslateToolWithSnapMarkingMenu;
break;
case 3:
RotateToolWithSnapMarkingMenu;
break;
case 4:
ScaleToolWithSnapMarkingMenu;
break;
By the way you can edit this mel and add any tools as your want .
Tony Su
Product Support
reid.j.w
in reply to: tony.su
Thank You Tony Su!
In my learnings, I had created an if statement based mel script that was operable. However, I like the option that you have provided much more.
I am currently tweaking your script and will follow up with my solution.
Regards and Cheers!
reid.j.w
Since I will ultimately be using the Touch Ring of my Cintiq 24HD, I will need to be able to scroll downwards and upwards through the tools. Therefore 2 hotkeys needed to be created.
This is my first take at mel scripting, and based on the suggestion of Tony Su, this is what I came up with that works great (so far).
1) CycleToolsDown Command (using the Alt+2 hotkeys) with the following mel script:
if (`whatIs "$CycleCount"` == "Unknown"){
	global int $CycleCount;
if ($CycleCount == 0){
	MoveTool;
	$CycleCount = 3;
}else if (($CycleCount >= 1) && ($CycleCount <=4)){
	switch ($CycleCount){
		case 1:
			SelectTool;
			$CycleCount = 2;
			break;
		case 2:
			MoveTool;
			$CycleCount = 3;
			break;
		case 3:
			RotateTool;
			$CycleCount = 4;
			break;
		case 4:
			ScaleTool;
			$CycleCount = 1;
			break;
		default:
			MoveTool;
			$CycleCount = 3;
			break;
}else{
MoveTool;
$CycleCount = 3;
2) CycleToolsUp Command (using the Alt+1 hotkey) with the following script:
	ScaleTool;
	$CycleCount = 1;
		case 1:
			RotateTool;
			$CycleCount = 4;
			break;
		case 2:
			ScaleTool;
			$CycleCount = 1;
			break;
		case 3:
			SelectTool;
			$CycleCount = 2;
			break;
		case 4:
			MoveTool;
			$CycleCount = 3;
			break;
		default:
			MoveTool;
			$CycleCount = 3;
			break;
}else{
MoveTool;
$CycleCount = 3;
Please feel free to critique!
I did try to make this script in my scripts directory and simply call it from the Hotkey editor, however, I got a little hung on getting the $CycleCount variable to keep its value. I had to suffice with this solution for now.
Thanks again Tony for the kickstart!
reid.j.w
Tony Su,
I liked your 'TranslateToolWithSnapMarkingMenu" option, however, for the life of me I can not find how to select the handles to move the object when that cool marking menu is displayed.
reid.j.w
(For future reference) Here is my solution which allows a hotkey to cycle between the Select, Translate, Rotation and Scale tools.
In addition, I added the ability to change the Move and Scale tools Axis between Object and World.
I have button 1 of the cintiq 24hd touchring assigned to cyleAxis. Button 3 of the cintiq 24hd touchring assigned to cycleTool.
There are 6 mel scripts total, and I added them to my ...maya\2015-x64\scripts directory.
*I'm sure that I should have done this in python, however, it was my first stab at mel scripting and I wanted to explore and learn.
userSetup.mel
//Name mel script userSetup.
//Defines custom user commands at application startup.
allGlobalVars();
allGlobalVars.mel
//Name mel script allGlobalVars.
//Declare all global variables
global proc allGlobalVars(){
	global int $g_currentTool;
	global int $g_select;
	global int $g_move;
	global int $g_rotate;
	global int $g_scale;
	//initialize variables
	initGlobalVars();
 initGlobalVars.mel
//Name mel script initGlobalVars.
//Initialize custom global variables.
global proc initGlobalVars(){
	global int $g_move;
	//Assign tool numbers to tools.
	$g_select = 1;
	$g_move = 2;
	$g_rotate = 3;
	$g_scale = 4;
 cycleTool.mel
//Name mel script cycleTool.
//Cycles between Select, Move, Rotate and Scale.
//Use 2 hotkeys with command being cycleTool($g_currentTool, "UP or DOWN").
global proc cycleTool(int $tool, string $direction){
	global int $g_move;
	if ($direction == "UP"){
		switch ($tool){
			case 0:
				ScaleTool;
				$g_currentTool = $g_scale;
				break;
			case 1:
				ScaleTool;
				break;
			case 2:
				SelectTool;
				$g_currentTool = $g_select;
				break;
			case 3:
				MoveTool;
				$g_currentTool = $g_move;
				break;
			case 4:
				RotateTool;
				$g_currentTool = $g_rotate;
				break;
			default:
				ScaleTool;
				print "EXCEPTION ...is scale tool from cycleTool's UP default switch\n";
				break;
	}else if ($direction == "DOWN"){
		switch ($g_currentTool){
			case 0:
				MoveTool;
				break;
			case 1:
				MoveTool;
				break;
			case 2:
				RotateTool;
				break;
			case 3:
				ScaleTool;
				break;
			case 4:
				SelectTool;
				break;
			default:
				print "EXCEPTION ...is current tool from Down's default switch\n";
				MoveTool;
				break;
	}else{
		print "EXCEPTION ...must supply a direction to cycleTool.\n";
 cycleAxis.mel
//Name mel script cycleAxis.
//Cycles the move axis of either the Move or Scale tool.
//Create 1 hotkey using the command cycleAxis().
global proc cycleAxis(){
	global int $g_move;
	if ($g_currentTool == $g_move){
		int $CycleMove = `manipMoveContext -q -mode Move`;
		if ($CycleMove == 0){
			//turn to object
			manipMoveContext -e -mode 2 Move;
		}else if ($CycleMove == 2){
			//turn to world
			manipMoveContext -e -mode 0 Move;
		}else{
			//turn to world
	}else if($g_currentTool == $g_scale){
		int $CycleScale = `manipScaleContext -q -mode Scale`;
		if ($CycleScale == 0){
			//turn to object
			manipScaleContext -e -mode 2 Scale;
		}else if ($CycleScale == 2){
			//turn to world
			manipScaleContext -e -mode 0 Scale;
		}else{
			//turn to world
	}else{
		pickTool();
 pickTool.mel
//Name mel script pickTool.
//Prompts user to select either Move or Axis tool for
//cycling the Move Axis options.
global proc pickTool(){
	global int $g_move;
	$response = `confirmDialog -title "Cycle Tools Axis"
	-message "Please choose Tools Axis to modify."
	-button "Move Axis"
	-button "Scale Axis"`;
	if ($response == "Move Axis"){
		MoveTool;
		cycleAxis();
	}else if($response == "Scale Axis"){
		ScaleTool;
		cycleAxis();
