HELP! - Need script that exports Vertex X,Y coordinates to textfile....
Hello. I desperately need a script that can export vertex points X,Y coordinates to a textfile like .csv. Like the following...
1. Select a set of vertex points.
2. Run script.
3. Browse for a textfile output and name it.
4. A .csv file is created with two columns X and Y for each vertex coordinates in relation to grid 0, 0 position.
Could someone help me with this script?
Thank you.
MedalHellWay
Ok, with more calm I have write a better script for stamp the selected Vertex Position of a ObjPoly.
Select The vertex and run script.
Save your file .csv with your name
Print the result in file .csv with separate columns for the x, y and z
I hope this can help you.
RadioRahim
I tried running this and all I get is:
X Y Z
with no coordinates.
I ran the script as instructed. Is this script supposed to create cooridnates in ths CSV file?
MedalHellWay
You have select the vertrex? The script work well...
X Y Z
-18.2595 -20.8713 0.0
-18.2595 20.8713 0.0
18.2595 20.8713 0.0
-18.2595 -20.8713 27.0743
-18.2595 20.8713 27.0743
Follow this step: Open Script, Save tha path with button "Path Save". Then Select the vertex and press "Stamp".
Script NOT work well,   try over and over.    works only sometimes??
Also how to get the vertex coordinate similar to the values found in the transform tool.   The api coordinates do not match.
transform tool values
x = -14.057
y = -1.286
values retrieved by script result for same vertex
x =-42.4729
y =-8.58307e-06
how can I get values shown in transform typein?      and why do I have to reset 3dsmax to get this script to run successfully a second time?
THanks,
Frustrated.
MedalHellWay
Yeah, you're right @Anonymous... The script is totally wrong and I do not understand how I did not control the error, Im sorry ... Test this if work for you:
try (destroydialog ::gvp) catch()
rollout gvp "Print Vertex Point"
Global obj, dir_path, outFile, sv
button c_path "Path Save"
button c "Stamp Vertex Pos. XY"
	on c_path pressed do
		dir_path = getSaveFileName caption:"Name Save File" initialDir:(getDir #export) filename:"PositionVertex_XY.csv"
        outFile = createFile dir_path
		on c pressed do
		selection.count == 1 and classof selection[1].baseobject == Editable_Poly
		obj = selection[1].baseobject
		format "Name: %\n\n" (selection[1].name) to:outFile
		format "% % % % %\n\n" ("X") (";") ("Y") (";") ("Z") to:outFile
sv = for i in $.selectedVerts do
	format "% % % % %\n" (i.pos.x) (";") (i.pos.y) (";") (i.pos.z) to:outFile
			close outFile
createdialog gvp style:#(#style_titlebar, #style_sysmenu, #style_toolwindow, #style_sunkenedge)
Below an example:
