I would like to see the ability to save a "snapshot" of the drawing settings in my template, much the way that layer states save the settings for my layers. Specifically, the command settings for each object, and default layers for objects. When I am working in a survey master file, I need things to use styles and layers for existing. When I am working in a design file, I have to go change all of those things, or create a second template for that purpose. This runs into the problem of having to keep multiple templates up to date. Not to mention various utility plans, where the layers and styles change yet again. If I could switch "toolspace" to a different set of items and save that, I think it would be a tremendous boost to my workflow.
