THANKS FOR THE NEW VERSION OF MAYA2015,but this little someguy has one little suggestion for my favorite software if you allowed. For the first time I open the 2015,I found many amazing function and some trouble .So ,the most important is the position of the keep faces together,When I use the LOW version of maya ,JUST ONE CLICK Icould activate this option and use it very convenient。BUT now I need open the preferences and select modeling part AND activate this option AND click the SAVE,when I want cancle this function ,you know I must do the same way once more.
THE secend suggestion for MAYA is the opration to delet the face or eadg when use the modeling toolkit ,I still remember the 2014 just use one hotkey I could delet IT ,but now I NEED use shift and ctrl in the same time ,it make the procese of topo modle not very SOFT,but it is not the big problem.
So.....my english read not smoothly, I use the web translate try to make it could be understand but I don't know IF it worked......
All the best with your work and expect for new update
THX for read 🙂
