A green line in my xref is printing thinner than a green line drawn directly on the sheet.
Both lines are zero thickness, set to print using ctb.
I noticed that when the plotstyle is set to adaptive it prints just the opposite, the sheet line is lighter than a line of the same color in the xref.
I'm trying to get lines of same color, one in xref, the other on the sheet file to print the same thickness.
I'm printing to PDF using DWG to PDF.
Any suggestions?
