I'm referencing in a WMS image (a momochrome LiDAR image) which shows fine on the screen. However when I plot, the image won't -- all other aspects of the drawing come through. It's not on a non-printing layer. I've fiddled with RASTERPERCENT, RASTERTHRESHOLD, and the plotter properties (currently using a PDF plotter but I have tried others with no success) but can't get the image to come through. Adding to the frustration, other images on the same server (i.e. color aerial) come through and plot without issue. Any ideas why this particular image won't plot? According to the WMS administrator, there is nothing on their end that "locks" the image prevening it from plotting.
C3D 2014
A little more detail...The LiDAR image is a greyscale image. It is one of many available layers on the WMS server where it resides. The full-color aerial will plot without issue (different layer, same server) but the greyscale LiDAR will not print. Changed all sorts of settings in the plot and no resolution found. Contacted the administrator for the WMS server and they have no idea either. Even went as far as trying to print out of 2012, 2013, and 2014 C3D. Nope.
