Every plotting comes out in the normal standard 'acad.ctb' colour instead of the assigned plotstyle that is definitely most definitely B/W with its own assigned lineweights.
I did everything relating to the plotstyles and printing options until coming to the conclusion that the problem is most probably caused by the 2D Wireframe visual style.
It seems to be corrupted as you can see below and the reset to default doesnt work for it (2d wireframe style) in this one particular drawing.
Anyone here experiencing the same problem and have or seen solutions to this?
Cheers, Thom.
