RESOLVED - WITH THANKS!
Thanks for your help, i have looked further into PC3 settings for this printer and have resolved this issue.
got almost the same problem as you. in my old plotter hp designjet 500 Plus i can print A1 and A0 drawings in just one paper size (a0 paper). But in hp designjet t790 i cant use A0 paper to plot my drawing in A1 size.
We have been recently upgraded to 64 bit Windows 7 and are now experiencing a very similar issue within AutoCAD 2012. The T790 cannot be found when trying to plot to it. However, it shows up in the plotter list.
What's funny is that the PS driver is working.
Duncanshort - Will you post what you did to resolve the issue?
Thanks in advance!
We have had the same issue with our T790 44 inch, plots that should be Ansi D coming out 11x17. Now I see HP is not making this plotter anymore, so I suspect it may be a driver issue and difficult to resolve.
I'd also like to know what changes were made to PC3 to restore functionality--we have been trying to edit ours repeatedly but unable to solve the problem Occurs with Autocad 2012 and 2014.
ugh, I hate adding to the "me too" lists! I've sent a private msg to the OP asking for clarification on what they did to fix this.
Fingers crossed the OP responds!
I failed to include what we are seeing here when plotting to an HP Designjet T790...using Acad 2013 on Win7/64 bit using the "44in HPGL2" type driver when someone plots out a D size print, the paper size is correct however everything being printed is reduced down in size to roughly a B size print.
Inventor and NX can plot correctly, it's only Acad that is having problems.
This particular issue I am assisting with, the plotter is in another state and is local to the client reporting the problem. I've setup the plotter on my pc and have had 50/50 success sending plots to it so far, ie, only once I was able to plot a D size print and the info being printed filled up the paper correctly.
What I was exploring during the troubleshooting process with this isse is a somewhat common known issue where for some plotters - for some reason or another - it's been discovered that the Acad plot window had to be set to Landscape but within the plotter configuration it had to be set to Portrait to plot correctly. That's when I was able to plot successfully but at the time I was not able to confirm that plot used the settings I had intended...when the client has some time, we'll connect up once more and I'll test that possible idea once more.
No word from the OP yet to my private msg. There is the possibility that person can no longer be reached at the email they left with Adesk when they created their account here.
just an update for what worked for our issue,
We had to adjust the HP Designjet T790 properties to specifically state the paper was coming off a Roll instead of the default "Printer auto select" for "Paper source" - which I believe this setting fixed the problem, but while we were in the plotter properties we also told it what type of paper it was.
We saved that to a .pc3 file and that appears to work now.
HTH someone since the OP is MIA.
i use AutoCAD 14 and whenever i try to print to size A0 or A1 on HP Designjet T790, it wouldn't print, sometimes it will print size A3 instead.
Please what do i do?
Can someone help with step by step method of solving this problem
