AutoCAD Forum
Scriptpro 2.0 not printing with the dwg to pdf driver.
20 REPLIES 20
Message 1 of 21
1184 Views, 20 Replies
Hello
I having difficulty batch printing using Scriptpro 2.0.  In short, scriptpro is using the simple batch file (see below), to add a xref and then printing using the DWG to PDF driver. I have tried using a paper printer, which works fine, so I suspect the problem is when scrippro calls the DWG to PDF driver.
I am using accoreconsole.exe application.
I inserted a "qsave" command after the xref is inserted, and the xref does get saved, so, I know the script is working up to that point.
As anyone seen this problem and does anyone have any possible solutions.
Thanks in advance.
L.
Batch.scr
Filedia
0
Proxynotice
0
Frame
1
Frame
0
Wipeoutframe
1
-xref
attach
"G:\My Docs\Engineering\Stamp.dwg"
6.35,6.35
1
1
0
-Plot
Y
Model
DWG To PDF.pc3
ARCH expand D (36.00 x 24.00 Inches)
Inches
Portrait
No
Extents
Fit
Center
Yes
electrical.ctb
Yes
Wireframe
C:\TEMP\dwgtest\pdfs\<acet:cBaseName>
N
Y
Filedia
1
20 REPLIES 20
Message 21 of 21
in reply to: pendean
First: no questions were asked!!!
Second: Virupaksha states: "ScriptPro can not be used against AutoCAD LT" which is true, but ACCoreConsole shipped with AutoCAD LT does work with Scriptpro.  ScriptPro does not seem to be the problem.  The PLOT command executes without any issues, the DWG to PDF driver simply does not produce the pdf output.
I will try other avenues for assistance.
”Boost
