Hello Everybody,
I have a user here that is having issues printing pdfs, and for the life of me I can't figure it out. When batch plotting out of AutoCAD only one of his drawings will rotate to be orientated portrait instead of landscape. He's using the same print settings on all the drawings.
Additional things I have ruled out:
This problem only occurs on his computer (cannot be replicated).
Only occurs when printing to PDF
Does not matter if printing to Adobe or Bluebeam.
Any Suggestions?!!?
Thanks!
We have a few automation settings that do a few things:
Any input is greatly appreciated. Thanks!!
"...This only happens on one computer..."
The one PC has a different or unique set of pagesetups most likely. Recreating their AutoCAD profile to match others may be one quick fix.
This one computer uses the standard corporate profile. That profile has been reset, repeatedly. And it doesn't have it's own page setups - this happens using the shared page setups that the whole company is using because all of our page setups are purged on save.
Behavior has been observed while plotting the exact same set of sheets, and importing the exact same page setup from the same network share. Page setup is irrelevant because it always happens on the first sheet - no matter what order the same set of sheets is printed in.
