Printing and Plotting
Active Member
0 Kudos
Post 1 of 7
Publish option error
303 Views, 6 Replies
09-14-2012 03:44 PM
It used to working until the last 2 weeks.
When I want to print multiple pages, I go to file/publish/add sheet to the list/change page setup.  Then problem starts:
1.  If it's plotting to paper, sometimes it only prints the sheets which are in the current opened file but not all the sheets on the list.
2. If it's plotting PDF.  There's a publish options button.  I used to be able to use the publish option button and select the location of my PDF files and would it be dividable PDF files or just one PDF file with multiple pages.  PROBLEM NOW: If I click that, it'll just freeze the screen forever until I push "Esc" then it'll cancel the whole publishing function.
does anyone have the same problem and how do you resolve this?  Thanks!
1,588 Kudos
Post 2 of 7
Re: Publish option error
09-17-2012 05:35 AM in reply to: Cad_enthusiast
Sounds like you turned on Background Publishing: turn it off in OPTIONS' Plot tab.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Member
0 Kudos
Post 3 of 7
10-16-2012 10:43 AM in reply to: pendean
Hi thanks for your comment. however, I turned the publish background on and still not working....
somehow the publish option button is not functioning suddenly. even i changed the publish details on options/plot and publish/automatic publish settings, it is not working....
1,588 Kudos
Post 4 of 7
10-16-2012 12:33 PM in reply to: Cad_enthusiast
A system restore back to a month it all worked may be what you need to do.
Active Member
0 Kudos
Post 5 of 7
10-16-2012 12:57 PM in reply to: pendean
Hi, you mean system restore AutoCAD 2013 or my window OS?
1,588 Kudos
Post 6 of 7
10-17-2012 06:03 AM in reply to: Cad_enthusiast
Windows OS, unless you know something changes in AutoCAD.
Active Member
0 Kudos
Post 7 of 7
04-22-2013 03:52 PM in reply to: Cad_enthusiast
Problem solved by repairing AutoDesk. =)
