In past versions, I could pick my tabs at the bottom of the screen and right click to publish multiple layouts at once, either using shift or ctrl to select them. I can no longer do that - I pick all the tabs, right click, but only one of the tabs is listed in the publish box. Did something change in 2015 that I am unaware of? Or is there another way I need to be picking the layouts? thanks
As far as I know, I am doing nothing differently. This is the way it worked for me as well. All of my layouts have defined page setups (although in the past that didn't matter - you could still publish a layout with an undefined page setup). However the problem does seem to be related to one drawing. Maybe I will rebuild it and see if that works.
I am having the same problem. I use the shift key to select multiple layout tabs but when the publish dialog box pops up only the first one I selected shows up. Is there a setting that changed that I’m not aware of? acad 2015 w/ windows 10 OS
