I have C3D 2010, 2011, and 2013 installed on my pc. I use the Publish command almost daily, and haven't had any serious issues with it when using 2010 or 2011. But in 2013, when I publish it just sits on the same screen and never actually publishes. I have tried turning off Publish in Background, I have checked that the printer support paths are the same as in 2010 and 2011, and I have tried Publish with different Page Setups. None of that has fixed the issue. Has anyone else encountered this and resolved it?
I just figured out a little more info. When I published this drawing using a different ctb file it worked. But it will plot fine if I go sheet by sheet using the original ctb file.
Here is the plot style that won't seem to work with Publish. It wouldn't let me post a .ctb file, so just rename it from .pdf, to .ctb and you should be able to look at it.
