AutoCAD Forum
Plotting in Paper space
7 REPLIES 7
Message 1 of 8
verdant1
501 Views, 7 Replies
Normally I plot in paper space and everything works well.  During the past two days for no explainable reason, when I plot in paper space all the lines ae much, much lighter and almost invisible, whereas if I plot the same drawing in model space the plot comes out perfectly, though not in scale.  I must have pushed a wrong button somewhere but wnat button is beyond me.  Any suggestions?
7 REPLIES 7
Message 2 of 8
hwalker
in reply to: verdant1
Welcome to the Forums
Are you using the same plot style in both model space and paper space?
Howard Walker
Left Handed and Proud
Message 3 of 8
verdant1
Thanks for your response.
To be honest, I didn't know what a plot style was until I read your post.  I'l researching that
topic now, but to answer the question I hadn't made any changes to plot settings before the plot in paper space changed to become so faint.  One day the plotter worked perfectly and then the next day I couldn't read the plot in paper space but plots in model space were fine.
Message 4 of 8
pendean
Message 5 of 8
verdant1
in reply to: pendean
Thank you.
Message 6 of 8
verdant1
The micro blog explanation is good but my acad version has no tab at the bottom of the screen for LWT.  Or at least no
icon that makes sense because I can't read what each tab represents since if I hover the cursor over the tab all I see is a dialogue box with some squares in it, no text explaining the function of that tab.  Also, in my plot dialogue box the "plot object lineweights" box does not allow me to check it.
However, it seems the monochrome-ctb plot style pen assignments box worked to at least bring the
plot into view in paper space.  I'll need to work on the lineweights in the layers which will probably
improve the quality of the plat quite a bit.
Thanks everyone who responded.  At least I can now plot to scale in paper space.  I must have inadvertently clicked on the wrong button sometime a few days ago.
Message 7 of 8
pendean
... And why must I ask what your version is? Do you not want help anymore? I'm curious about it.
Right-click on those lower-left icons, uncheck USE ICON and letters will replace the icons. Hope that helps.
When checkboxes are unavailable it usually means another checkbox needs to be on (or off): is there a reason you cannot tap the HELP button on the PLOT popup and read up in it? Again, I'm just curious about your process.
Message 8 of 8
verdant1
Thank you Dean.  This really helps.  I now have the words instead of the iconc available and I am able to plot in paper space now because I chenged to greyscale which helped and seems to have solve the problem.  The qustion in my mind is how it changed one day from greyscale.  Guess I'll never find out.
”Boost
