Hi Friends,
I have a problem with printting. when ever i give a print on my HP Plotter, print starts instantly.
But soon after closing autocad, plotter shows error... stops printing..
please help me out... i have loads and loads of drawings to print....
Thanks & regards,
BLuefox
Make sure you have the most current printer driver from HP's web site.
I have some problem!
Then i try to send print task (or make preview) in DWG TrueView 2013, 2014, i take "FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at e2561fe6h"
It be, then a use real prtinters such as HP5200, HP3525 (they configurade by HP uneviersal driver), but one of my printers work correct it's HP 1300 (it dosnt use HP uneversal driver). Then a use DVG to PDF - print task (or make preview) work good.
I use Windows 7 Professional SP1 32bit or 64bit
Try this download for the HP Universal Printer Driver:
http://h20565.www2.hp.com/portal/site/hpsc/public/psi/swdHome/?lang=en&cc=us&sp4ts.oid=4157320
AutoCAD does best with non-PostScript drivers, so try the PCL5 driver first.
Another thing that may help is setting FULLPLOTPATH to zero within AutoCAD.
Additionally, if the printer is on a network print server, try installing the driver for it as a local printer using a TCP/IP port.
