I have a drawing, that when I select a monochrome.ctb style in the Plot Style Table, the drwing still plots with layer color.
I opened the layer manager and the VP Plot Style and Plot style are greyed out, and I can not make a change.
Any suggestions?
AutoCAD 2012, using 2007 .dwg format.
Thanks.
Moderator;
Please move this post to the correct location, if needed.
Solved by RockyBrown4134. Go to Solution.
I have figured out my problem. The drawing contained a layer, that the color was set off of the true color color tab (Ex. 213,183,251). This layer was the only layer plotting in color when the monochrome CTB was selected. I change the color to a color on the Autocad Color Index (ACI) (Ex. 213). That cured the porblem. I don't know why the True Color acted that way, other than being a "true color".
