AutoCAD Forum
Plot Style Monochrome selected, drawing plotting in color
1 REPLY 1
RockyBrown4134
1308 Views, 1 Reply
I have a drawing, that when I select a monochrome.ctb style in the Plot Style Table, the drwing still plots with layer color.
I opened the layer manager and the VP Plot Style  and Plot style are greyed out, and I can not make a change.
Any suggestions?
AutoCAD 2012, using 2007 .dwg format.
Thanks.
Moderator;
Please move this post to the correct location, if needed.
If this response answers your question, Please mark this response as "Accept as Solution"
Rocky Brown
AutoCAD 2020 / Inventor 2020 / Plant 3D
1 REPLY 1
I have figured out my problem. The drawing contained a layer, that the color was set off of the true color color tab (Ex. 213,183,251). This layer was the only layer plotting in color when the monochrome CTB was selected. I change the color to a color on the Autocad Color Index (ACI) (Ex. 213). That cured the porblem. I don't know why the True Color acted that way, other than being a "true color".
Rocky Brown
”Boost
