Printing and Plotting
New Member
tallboy
Message 1 of 5 (141 Views)
oce tds600 plotter shifting drawings
141 Views, 4 Replies
07-24-2003 10:29 PM
we just got a new oce tds600 and have started to have problems with it. when we send a drawing to the plotter directly from autocad2003ldd (win nt/2k/xp enironments) in landscape, we get a sheet of paper 24x36, but the drawing is shifted over to the right 1/3rd of the way, so we have 1/3 white space, 2/3 of what we actually wanted to plot, and 1/3 of what we wanted to plot missing off the right side. when we send it portrait, we get the entire drawing, but with 12" of white space up top.
point me in the right direction?
*Schmidt, John
Message 2 of 5 (141 Views)
Re: oce tds600 plotter shifting drawings
07-25-2003 12:32 AM in reply to: tallboy
Which driver are you using? We're using Raster
Driver V2.7 with no problems at all, on LDD2i. Check on the Finishing tab in the
driver - we have Alignment set to Upper left. With a new purchase, I'd expect
the OCE people to help you get started.
John
we
New Member
tallboy
Message 3 of 5 (141 Views)
Re:
07-25-2003 02:54 AM in reply to: tallboy
newest drivers. changing the alignment doesn't seem to make any difference.
*Schmidt, John
Message 4 of 5 (141 Views)
Re:
07-25-2003 04:48 AM in reply to: tallboy
I assume the plot previews in AutoCAD look OK? Have
you tried adjusting the Shift functions on the Finishing tab? Do you have access
to the Oce Remote Logic program group? Check the media settings there. If
those don't get it for you, it sounds like an OCE tech is going to have to
go into the controller settings, (not normally available to end users). It
really sounds like it's internal controller settings that need to be
adjusted.
You might try contacting Scott Shepherd around here
- he's now working for OCE.
John
newest
difference.
Valued Contributor
roger.womersley
Message 5 of 5 (141 Views)
07-27-2003 09:53 PM in reply to: tallboy
Sounds silly but are the correct paper sizes set in the print engine control panel ? These should be reflected in the controller System Control Panel window. Oce define their roll sizes by the shorter dimension, i.e., A1 roll is 594 mm. Not too sure on imperial equivalent but 24" paper is ARCH D or D+ I think. Is the paper loaded correctly on the spindle ? Also media series set to DIN or ANSI on the controller depending on metric /imperial sheet sizes.
I use the HDI driver. The Windows System driver doesn't cut it for me in Autocad although Oce have a new Windows system WPD driver for some TDS models on their web site that does a good job with both raster and vector info.
Best of luck...
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
