AutoCAD Forum
Object lineweight
4 REPLIES 4
JFN_KSH
825 Views, 4 Replies
Object lineweight
I have an interrogation:
If the lineweight in my .pc3 file is set to "Use object lineweight" & that color is assigned to a layer with the lineweight set to "Default" How is the lineweight determined when plotting (assuming no lineweight overide on any objects)?
4 REPLIES 4
nestly2
in reply to: JFN_KSH
LWDEFAULT system variabe
JFN_KSH
Thanks! Smiley Happy  I guess that's bad for us since this system variable is local & it could be different on all workstation, meaning different plot thickness for everybody...
pendean
Automate with a 'standard' lisp that is auto-loaded using the ACADDOC.LSP file on each PC, or pre-loaded as a reactor when PLOT or PUBLISH are invoked. AutoCAD is more than a line drawing program, use it's full potential.
JFN_KSH
in reply to: pendean
yeah, great idea! I already have the workstations set with the acaddoc.lsp so its load our central LISP file on the server. I'll just set the variable there... Thanks!
”Boost
