I have an interrogation:
If the lineweight in my .pc3 file is set to "Use object lineweight" & that color is assigned to a layer with the lineweight set to "Default" How is the lineweight determined when plotting (assuming no lineweight overide on any objects)?
Solved by nestly2. Go to Solution.
Thanks! I guess that's bad for us since this system variable is local & it could be different on all workstation, meaning different plot thickness for everybody...
yeah, great idea! I already have the workstations set with the acaddoc.lsp so its load our central LISP file on the server. I'll just set the variable there... Thanks!
