Printing and Plotting
Valued Contributor
Rikkes
Message 11 of 16 (951 Views)
Re: not printing excel ss pasted into autocad
01-05-2010 01:08 AM in reply to: stevencrouch1226
I have the same problem but when I cut and paste small objects it works just fine.
When I try to paste a large sheet the plot preview shows the sheet but when I try to print (Canon IX4000) the proces is cancelled.
Very strange. I had the same problem in 2009 with PDF and I had to change something but I don't remember what :-(...
I use the paste / copy function a lot so it would be nice if it worked properly.
New Member
newfoundfreedom
Message 12 of 16 (951 Views)
02-11-2010 04:38 AM in reply to: stevencrouch1226
Has anyone found a reliable solution to this? I too, am experiencing this issue.
New Member
oce_drivers_support
Message 13 of 16 (951 Views)
05-20-2010 09:15 AM in reply to: stevencrouch1226
As for Oce printers, you will find the answer in the Océ Online KnowledgeBase (http://okb.oceusa.com/kbexternal/categoryBrowse.do)
then entering KM33783 in the 'Open by ID' window.
Hope this helps
New Member
imansuri
Message 14 of 16 (511 Views)
09-10-2012 10:22 AM in reply to: stevencrouch1226
i have been using autocad-13 on windows 7 pro,  64 bit operating system and having same issue with excell files. i import excell files through Edit>Paste special.   schedules from excell dose come correctly in to paper space but i am not able to print them or make pdfs.  I have been facing same issue in all autocad versions from 2008.  we do have autocad 2007 in old computer and that 2007 do print excell schedule from same file.......!
we save all our autocad files in 2007 version to accomodate our consultants. will it be a issue?  i just download PrimoPdf from internet to make pdfs and it dose make pdfs with excell schule in paperspace without any issue on autocad 2013...!    but no sucess while printing with Hp plotter, canon laser printer and Adobe pdf maker...!
please let me know if you are facing same issue as me or if you have got any solution for this issue.
thank you very much.
New Member
houman
Message 15 of 16 (316 Views)
09-25-2013 09:14 AM in reply to: Rikkes
It has been a problem since Acad 2010 I believe, BUT after you paste the excel and it does not print, select the excel image and in the property side menu at the buttom change the plot quality to monochorom and you are done, some drivers do not support high graphice images. pls see the attached file incase you can not find the menu.
good luck
New Member
imansuri
Message 16 of 16 (311 Views)
09-25-2013 11:04 AM in reply to: houman
Thank you very much.
Imran Mansuri, Intern Architect
ATKIN OLSHIN SCHADE * **ARCHITECTS**
**www.aosarchitects.com*
1807 SECOND STREET, SUITE 34 *SANTA FE* NM 87505 TEL 505 982.2133
125 SOUTH NINTH STREET, SUITE 900 *PHILADELPHIA* PA 19107 TEL 215 925 7812
