I apologize ahead of time if this problem has already been solved. Any links to solutions, or material already posted on this forum is appreciated.
I'm having a problem with "phantom" lines appearing in PDF plots.
The Situation:
The firm I work for often uses Excel tables in Autocad LT 2013.
I have learned through experience its better to use a linked table, but in this situation only paste special is an option due to time constraints.
Basically when we try to plot a DWG with tables specially pasted in the drawing space phantom lines appear.
But only when we try to convert to PDF. In the plot preview everything is fine, but when the PDF is created vertical lines appear in the tables on the actual PDF.
I've tried many different options to fix this but so far the only thing that has worked is, converting the DWG to a DWF and opening in Design Review. From there I plot to PDF and everything is fine, no lines appear.
In the DWG I have tried tweaking the Plot Quality for the "pasted" tables to no avail.
If anyone has a solution for this I would greatly appreciate it.
Attached is a PDF of the DWG with the issue.
Thats the driver I've been using. I tried using both Adobe drivers in the drop down list and neither work.
I'm wondering if this is an AutoCAD issue, possible a corrupted plot driver.
BTW, a PDF doesn't lie and shows the program it was created from and more. Screenshots attached, you'll recognize yours then you will see mine from 2013.
The attached DWG is one of the files we were having the issue with.
I just removed the titleblock for privacy otherwise this drawing is complete.
As far as the PASTESPECIAL process:
Once the window opens I select paste link, then Micosoft Office Excel Worksheet.
I apologize, I was reading your earlier post wrong.
I was using the Adobe PC3 driver, not the one you recommended.
The one you recommended has seemed to fix the issue.
I just tried plotting the suspect file with no issues.
I can't Thank You enough.
I am a student at ITT Tech and having the same issue with one of my print when i am creating a PDF for my drawing a phanton line is appearing on the spread sheet. This answer have helped othe user solve the problem but i was not able to follow. can you please tell me in steps to print in built in dwg thing
