AutoCAD Forum
HP designjet 1050C does not plot correctly
2 REPLIES 2
475 Views, 2 Replies
Platform: Windows 7, 64bits
AutoCAD version 2012
Printer: HP DesignJet 1050C
Dirver version: 4.91
Within in project We are creating PLT files. All drawings have the same Layout setup with a size of 1409*841mm. Some drawings create good PLT files. But some drawings create PLT files with a plot area of 903.98 x 1.40 mm and a constant size of 127 KB. Has anybody experienced this problem. And is there a solution for this problem? Our clients is demanding these PLT files.
Thanks in Advance!
Leo
2 REPLIES 2
pendean
if the problem is limited to certain files, then use the names pagesetups from the good files instead.
Explained in HELP like here http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%202010%20User%20Documentation/index.html?url=WS1a91938...
and here http://www.youtube.com/watch?v=y9ePhIBu4v8
http://thecadgeek.com/blog/2010/04/import-page-setups/
in reply to: pendean
Thanks for your tip! This solves the problem.
Regards Leo
”Boost
