Printing and Plotting
*Molinaro, Sam
Message 1 of 4 (401 Views)
How to print white text on black geometry?
401 Views, 3 Replies
12-09-2002 01:29 AM
How can I print white text on black geometry.
I am using AutoCAD 2002 and a HP DesignJet 755CM.
I am plotting with the default acad.ctb (color table) and set the text
object color to color 255.
This produces white text with small black dots - close but not good enough.
I tried various settings but unable to get completely white text on black
geometry.
What am I missing?
Any assistance would be greatly appreciated.
I am also posting in the "plotting/printing" news group.
I have searched both newsgroups and autodesk tech docs.
Thanks Sam
*Eloy, Francisco
Message 2 of 4 (401 Views)
Re: How to print white text on black geometry?
12-09-2002 01:54 AM in reply to: *Molinaro, Sam
Have you tried True Color RGB 255,255,255 ?
You might have better luck at the Print-Plot Newsgroup.
The Printing and Plotting newsgroup can be accessed in either of the
following ways:
By NNTP newsgroup reader at
news://discussion.autodesk.com/autodesk.autocad.print-plot
By HTTP (web-based) interface at
http://discussion.autodesk.com/WebX?14@@.ee77ef9
HTH
Francisco
"Sam Molinaro" wrote in message
news:07E23EE284B849F28D4F0557B5D6C052@in.WebX.maYIadrTaRb...
enough.
> geometry.
> What am I missing?
> Thanks Sam
*Molinaro, Sam
Message 3 of 4 (401 Views)
Re:
12-09-2002 04:32 AM in reply to: *Molinaro, Sam
Thanks for the input.
It seems that setting the screening to 0 using the plotter configured with a
"system" driver works well; however, using the AutoCAD driver does not give
you the same results. In fact, if you set screening to 0, it is completely
ignored and the color beneath shows through.
Thanks for your assistance
Sam
"Francisco Eloy" wrote in message
news:12E44CC281B21878A037321ABDE3C75A@in.WebX.maYIadrTaRb...
> following ways:
> HTH
> Francisco
> enough.
black
> > geometry.
> > What am I missing?
> > Thanks Sam
*Sapp, Mike
Message 4 of 4 (401 Views)
Re:
12-09-2002 07:04 AM in reply to: *Molinaro, Sam
Check the pc3 file. If you have the Graphics/ Lines merge set then they
do show through. If you have to overwrite then they don't. You then
have to be carefull about draw order.
Mike
>Sam
>>following ways:
>>HTH
>>Francisco
>>enough.
>black
>>>geometry.
>>>What am I missing?
>>> Thanks Sam
Announcements
Need installation help?
