Printing and Plotting
Valued Contributor
WillieArolf
Message 1 of 4 (637 Views)
How to Print multiple layout pages in a printer
637 Views, 3 Replies
10-14-2012 09:56 PM
I have multiple layout pages (58 pages) and would like to print them in a printer at once. How do I do that?
Currently, I open 1 layout at a time then print it 1 by 1, in which its killing me specially if I do have lots of drawings.
Publish does saving in DWF, PDF... But does not print in the printer.
Thanks & Regards,
Willie
Autodesk Product Design Suite Premium 2012
Windows 7, 64-bit
In order to publish to a printer you need to have a valid page setup for that printer to use. In any drawing use the page setup manager to create a new page setup. It will give you the plot dialog so you can select the printer and all other settings you need. Save this drawing and in the publish dialog box highlight all your sheets then in the page setup field pick on the top page setup and a down arrow will appear. Pick that and select import then find the drawing you just saved and get the page setup you created.
M_Hensley
Message 2 of 4 (621 Views)
Re: How to Print multiple layout pages in a printer
10-15-2012 04:04 AM in reply to: WillieArolf
pendean
Message 3 of 4 (612 Views)
10-15-2012 06:19 AM in reply to: WillieArolf
What version of AutoCAD are you using?
PUBLISH command can aim at any printer/plotter you have, as well as the two 'other' options you mentioned: it's what it does. Did you look it up in HELP before posting? It really does explain a lot.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Valued Contributor
WillieArolf
Message 4 of 4 (602 Views)
10-15-2012 05:35 PM in reply to: M_Hensley
M_Hensley,
Thank you for the HELP exerted on my query.
Thanks & Regards,
Willie
Windows 7, 64-bit
