Printing and Plotting
*Xing
Message 1 of 7 (240 Views)
how to add a printer and plotter for autocad program?
240 Views, 6 Replies
09-03-2002 04:06 AM
I installed Autocad program into a new computer, now I need to configure
the printers for it. When I opened Add Plotter wizard, I faced three
choices, they are "My Computer", " Network Plotter Server" and "System
Printer". My company use reguar network printers and plotter, do I need to
choose Network Plotter server"?
Thanks for your help,
Xing
Intern Architect, 3D Modeler & Web designer
www.roularchitects.com
*Satterthwaite, Kevin
Message 2 of 7 (240 Views)
Re: how to add a printer and plotter for autocad program?
09-03-2002 04:06 AM in reply to: *Xing
Hey Xing,
If the printer/plotter is connected to your physical computer then start
with the "My Computer" option, or if the printer/plotter is out on the
network then start with the "Network Plotter Server" option
Hope that helps
"Xing" wrote in message
news:BC8E770E9DD7EE3DE49CE0C04D46986F@in.WebX.maYIadrTaRb...
to
> Xing
*Xing
Message 3 of 7 (240 Views)
Re:
09-03-2002 05:30 AM in reply to: *Xing
Kevin:
The printer/plotter is connected to a network, and my computer is connected
to network too. So I guess I need to use "Network Plotter server" option.
But based on the "Add-a-Printer" wizard, I need to use "My computer" since
this option will install the printer/plotter driver for my computer
specifically.
Did I get it right?
Xing
"Kevin Satterthwaite" wrote in message
news:87E162D30A0FE5D4CC939A550E07FAD2@in.WebX.maYIadrTaRb...
> Hey Xing,
> Hope that helps
configure
> to
> > Xing
*Mark
Message 4 of 7 (240 Views)
Re:
Xing
easier to configure as a system printer and point to the desired printer
in your printer folder (windows start/settings/printers)
if it does not show there, then add it using the standard windows to
add the printer first then configure AutoCAD... you might get more help
at the AutoDesk.AutoCAD.print-plot user group, or read the AutoCAD
help/manual, it is quite simple and straightforward.
mark
news:305F36EADBB93838DD90EEA751810298@in.WebX.maYIadrTaRb...
> Kevin:
connected
> specifically.
> Did I get it right?
> Xing
> > Hey Xing,
> > Hope that helps
> configure
need
> > to
> > > Xing
Re:
Xing,
If the printer/plotter is attached to the computer via the Parrallel
Port/USB Port etc... then start with the "My Computer" option.
If the printer/plotter is attached to some other device on the network then
start with the "Network Plotter Server" option.
You might have the "My Computer" option confused. Use this option if the
Printer/Plotter is atached to your computer via a cable of some sorts.
(parrallel cable, USB cable etc...)
/kevin
> Kevin:
connected
> specifically.
> Did I get it right?
> Xing
> > Hey Xing,
> > Hope that helps
> configure
need
> > to
> > > Xing
*Talsky, Jack
Message 6 of 7 (240 Views)
09-04-2002 12:39 AM in reply to: *Xing
From your description you should be using the network plotter.
Jack Talsky
to
> Xing
*Xing
Message 7 of 7 (240 Views)
Re:
09-04-2002 10:18 AM in reply to: *Xing
Kevin:
You are right. Your explanation is rather straight forward too. Thanks,
man.
Xing
news:024A6DFE2CECEF4272572AAD1F805543@in.WebX.maYIadrTaRb...
> Xing,
then
> /kevin
> > Kevin:
> connected
option.
since
> > specifically.
> > Did I get it right?
> > Xing
> > > Hey Xing,
start
> > > Hope that helps
> > configure
three
"System
> need
> > > to
> > > > Xing
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
