Printing and Plotting
*Molinaro, Sam
Message 1 of 4 (719 Views)
Formula to convert inches to JPG pixel sizes?
719 Views, 3 Replies
05-08-2002 11:50 PM
Hi all,
I am using AutoCAD 2002 and plotting to JPG format which gives me output
options of standard screen resolutions (i.e. Super XGA - 1280 x 1024
Pixels). My question is, is there a formula to calculate the Pixel
equivalent of an imperial sheet size .. say a 11" x 17" sheet. I typically
set scale to fit but this means that there is "blank space" at the top or
side of the jpg image depending on the proportions of the drawing and the
selected pixel sizes. I am hoping to eliminate this "blank space" by
providing the exact pixel sizes.
Thanks in advance.
*Support\, Autodesk
Message 2 of 4 (719 Views)
Re: Formula to convert inches to JPG pixel sizes?
05-09-2002 01:23 AM in reply to: *Molinaro, Sam
Sam,
See if this document helps you.
Understanding dpi resolution with the Raster File Formats HDI plotter driver
http://support.autodesk.com/getDoc.asp?id=TS55657
Danny Hubbard
Autodesk Product Support, Platform Technology Group
http://www.autodesk.com/support
"Sam Molinaro" wrote in message
news:FDA0CFB59BFB98C84DF756E072FAD851@in.WebX.maYIadrTaRb...
> Hi all,
typically
> Thanks in advance.
*White, Ian A.
Message 3 of 4 (719 Views)
05-09-2002 06:43 AM in reply to: *Molinaro, Sam
On Thu, 9 May 2002 07:50:22 -0700, "Sam Molinaro"
wrote:
>Hi all,
Work out what resolution you want the image to be (i.e. whether you want
150 dpi, or 200 dpi, or 300 dpi, or 600 dpi) and then multiply the
resolution you have chosen by the length in inches.
Ian A. White, CPEng
WAI Engineering
Sydney 2000
Australia
Ph: +61 418 203 229
Fax: +61 2 9622 0450
Home Page: www.wai.com.au
*Molinaro, Sam
Message 4 of 4 (719 Views)
Re:
05-09-2002 09:49 PM in reply to: *Molinaro, Sam
Thanks to all that responded. It is very simple now that I understand what I
am doing.
"Ian A. White" wrote in message
news:a9rldu4q30av65055s6ietohlv4l1aqpui@4ax.com...
> wrote:
> >Hi all,
typically
> Regards,
> Ian A. White, CPEng
> WAI Engineering
> Sydney 2000
> Australia
> Ph: +61 418 203 229
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
